Kokok
Flight distance : 1700377 ft
Philippines
Hi,
Cant find much info on the net so im posting this here. Apologies if there are similar threads already (did a search, couldnt find one).
My p4 is about a year old now and i've noticed that the plate that pushes the props to lock are not as "springy" as they used to be. I am hoping to replace them with the prop mount system found on the p4 pro (the one with the spring). Are they compatible?
Also, would the props that came with my p4 fit on the mounting system on the p4 pro?
Thanks!
