Bekaru Tree
Flight distance : 15513100 ft
South Africa
For any users interested in this thread - i am lucky to have access to a retired radio frequency specialist (40 years RF specialist with marconi - now retired) who is kindly helping to trouble shoot my problem.
It took just one email explaining my issues for him to arrive at the same thoughts/ possibilities it has taken me a year to get to.
For those who are interested in a little bit more advanced RF trouble shooting - this might be interesting to you.
This post does not contain solutions but shows some insight in how to trouble shoot the issue.
His email back to me is below: My outgoing email is not included - it is not nesesary to include here or this post would be too long and anyway everything said in the outgoing email is already in this thread somewhere.
Greetings and salutations Mr Dean,
Unfortunately there is nothing worse than the intermittent type problems as they are always the most difficult to isolate, which I am sure you didn’t want to hear! It’s about a process of elimination really.
A very thorough and clear explanation of the problems…you sure have been doing your homework and super impressed with your reasoning.
Solar flares are only really relevant at much lower frequencies and local interference such as boats and cars etc is only very localised to a very short distance, but as you rightly say you may have two different problems.
It easy to say, but the obvious thing to do is to determine if it is a data or RF problem
Will sit down and give it all a good think through tonight, but my gut feeling is that at least one of the problems is something to do with the way the controller is talking to the “device”.
I will have to do a bit of homework as I don’t remember too much about the setup, but as I remember you connect a mobile phone or tablet to the controller so therefore it is the phone / tablet that is giving the erroneous display etc. On the face of it there seems to be some sort of problem between the controller and the device….lack of memory, synchronising/ dater transfer or just sheer overload problem or whatever.
It would certainly narrow down the options an enormously if you could try a good known “device” as to my mind this has to be eliminated before delving any deeper. What to do about it however is not easy as there is no point in shelling out for a new one if there is no improvement. If it were here I’d go to Argos, buy one try it and if it was no improvement just take it back and say you’ve changed your mind…easy peasy!! As an old time RF engineer, computers and RF are totally incompatible and there should be a law against them having anything to do with each other!! The interference from digital equipment is incredible and spreads all sorts of horrible noise and muck across a large frequency spectrum… a curse upon the lot of them!
If it is a mobile /tablet it is very important that there are no other programmes or software running in the background and that all the memory is made available as if the ram gets overflows it can cause all sorts of time lags and delays. The screen is pretty well down the pecking order as the software does all its “sums” first before thinking about updating screen but if memory is shortage the video could well pixelate.
Is there any way you can turn the video / camera resolution down to a lower level. Are you using the full 4K mode? Obviously the higher the resolution the greater the greater the information being processed, so lowering the resolution to see if it makes any difference might at least narrow things down.
I would certainly try changing the receive / transmit frequencies if you can. If its anything like wi-fi, the 2.4 gb frequencies have longer range, but the 5GB frequency has shorter range but faster transmission rates so would be worth experimenting with.
Couple of points if you can clarify for me…
Can let me know what the “device” is and how it connects to the controller…is it hard wired or via Bluetooth or whatever
Am I correct to say this problem has existed from day one in one way or another.
Did it have to go back to China to be checked out, or did the dealer check it out for you?
Deano, let me give it a bit of thought and will try and find the information on the device on the web.. give me a day or so to get my brain back into gear as it sort of switched off this sort of thing since retirement!! |
