Inferno-Videos
Flight distance : 889688 ft
MrJayd as Jeff says one of the differences between the Pro and the Pro+ is the fact that you can use a secondary screen, this is either 2 tablets so someone else can see what you see or so you can use DJI goggles or any other FPV goggles like the FatShark HD v.3. Also another thing is the upgraded mondule is for using the LightBridge HD recording device/s. The module is available to buy as an upgrade for all of the 300 series RCs that use the OTG module (P3A, P3 4K, P3P, P4, P4A and P4P) for around $100US or £80UK see link below, again like Jeff said. Before anyone asks, this won't fit the P3S or P3SE as they use a different controller.
At the end of the day the Pro+ is higher model that costs more because it has more features than the P4P, like the better module for one. Not sure if they make a dark grey upgrade module but the white one will still fit.
You could ring DJI suport and ask for a part number, if the phantom 4 pro+ obsidian has the HDMI module then I guess you must be able to buy it sepperately.
https://store.dji.com/product/ph ... Hi6IyBoCWPIQAvD_BwE |
