Compatible Controllers for Ryze Tello
12
109810 48 2018-3-8
Vas
Flight distance : 249 ft
Here's a video for how to use any controller with the Tello (or any other drone that connects through WiFi):
Hope it helps!
There's no video feed in the Tello app but that seems to be a thing since the last updateand I'm not getting any video feed in the Tello app with the controller or without. (Great going Ryze :|)
If a few people hit subscribe I'll upload some other cool tricks like how to set up a portable wifi repeater to boost range/increase video quality etc.
2018-5-3
Metarcana
New Zealand
fansc0b26c7d Posted at 2018-5-1 18:05
I am having the same issue as TLG above.
I have a Samsung Galaxy s6 with Android 7.0 which I can not get the T1d to connect to.
I managed to fix the problem and the T1d is now working as intended.
Here is the fix for anyone having a similar problem.
Symptom:
Inside the Tello app, you can see nothing in the Bluetooth settings tab, i.e. no devices to select to connect to, only the picture of the controller and the how to connect steps.
Steps:
1) Double check that Bluetooth is active on the phone (mine always was)
2) In the Tello app, go back to the main page, and in the top centre there are some icons for wifi (drone connection), Bluetooth etc
3) If the Bluetooth icon here is grey, then Bluetooth isn’t being passed to the app correctly, even though you have made sure it is turned on in step 1.
4) When you first installed the app, it asked you to give access to a variety of phone functions. Sometimes this doesn’t work properly because the app boots up before finishing asking or your phone has more restrictions outside the app.
5) To check or fix this, go into you phones settings, and look for the application settings, and find the Tello app. There should be a permissions setting under this. Check that it has access to everything, and especially make sure it has Bluetooth requested (I had to grant additional access here, even after accepting all 4 requests from within the app).
6) Restart the Tello app. You should now be able to see your T1d in the Bluetooth settings tab of the Tello app.
7) Another option to try is uninstalling and reinstalling the app which can trigger not only the latest app and clean permissions, but any necessary firmware updates.
2018-5-7
Tampa Drones
Metarcana Posted at 2018-5-7 16:27
I have a LG V20 and have the same problem. My problem is though that when I go into the app permissions, I only have 2, for storage and location, no Bluetooth. Therfore, not being able to pass Bluetooth controls to the app...
2018-6-18
FlyaDrone
Flight distance : 188750 ft
See YouTube and search tello for much info and tellopilots.com is another forum with much user information available.
2018-7-14
FlyMaine
Flight distance : 389482 ft
I’ve had a Tello for several weeks and really appreciate how inconspicuous it is and how easy it is to get a nice aerial snapshot with it. The GameSir T1d works with iOS devices and is now in stock at B&H Photo.  Tello holds its position well in very light wind but has  a Short WiFi range so keep it close to you, especially if there’s any wind.  It’s a great little drone if you stay within its limitations.  Have fun!
2018-7-14
stefan111
Bulgaria
Lucas775 Posted at 2018-3-8 19:29
Scratch coding? please explain.
https://dl-cdn.ryzerobotics.com/ ... +Scratch+Readme.pdf
2018-8-18
PILOT TRUCKER
J have a Sony, game controller any recommendation on how to blue tooth it?
2018-10-5
carl hanson
I have done my research and found that most of the gamesir controllers will work on the RYZE TELLO drone also a few of the madcats. But please ask sellers beforehand as I brought one without asking and sad to see it wouldn't pair. I 100% know the gamesir Bluetooth controller work. And eBay is best bet or straight from DJI if they sell. . All the best
2019-2-9
tranedepriest
Have you tried flying the Tello in VR mode since applying the Gamesir World hack?  I ask because some remappers apparently impact VR mode.
2019-5-2
12
