Metarcana
New Zealand
I managed to fix the problem and the T1d is now working as intended.
Here is the fix for anyone having a similar problem.
Symptom:
Inside the Tello app, you can see nothing in the Bluetooth settings tab, i.e. no devices to select to connect to, only the picture of the controller and the how to connect steps.
Steps:
1) Double check that Bluetooth is active on the phone (mine always was)
2) In the Tello app, go back to the main page, and in the top centre there are some icons for wifi (drone connection), Bluetooth etc
3) If the Bluetooth icon here is grey, then Bluetooth isn’t being passed to the app correctly, even though you have made sure it is turned on in step 1.
4) When you first installed the app, it asked you to give access to a variety of phone functions. Sometimes this doesn’t work properly because the app boots up before finishing asking or your phone has more restrictions outside the app.
5) To check or fix this, go into you phones settings, and look for the application settings, and find the Tello app. There should be a permissions setting under this. Check that it has access to everything, and especially make sure it has Bluetooth requested (I had to grant additional access here, even after accepting all 4 requests from within the app).
6) Restart the Tello app. You should now be able to see your T1d in the Bluetooth settings tab of the Tello app.
7) Another option to try is uninstalling and reinstalling the app which can trigger not only the latest app and clean permissions, but any necessary firmware updates. |
