warrenski
South Africa
sidtx Posted at 2018-3-9 14:59
As I understand it, our batteries are "smart"-- i.e. they have smart electronics embedded within them.
These smarts make it possible to recharge without damage, a battery that is not fully discharged.
You're right that the aircraft batteries have quite a bit of built-in intelligence, for example, to be able to accurately calculate remaining flight time and manage the rate of discharge, but the aircraft battery and RC battery are chemically different.
As I understand it, the aircraft uses lithium polymer batteries while the battery inside the RC is a lithium-ion type, similar to what you'd find in your mobile phone. It's the aircraft batteries in particular that you need to treat with care, because you can significantly reduce their lifetime by for example leaving them stashed inside of a hot car, or draining them completely. I recommend spending some time watching the video I posted earlier in this thread - the guy maybe comes across as a bit paranoid, but it's an excellent explainer. |
