Rodador
Flight distance : 427520 ft
I went to a nearby park to fly my Spark today but this time I thought I'd launch from the parking lot because there wasn't anyone around & I planned on being fast.
I setup my RC & DJI Go 4 app then powered on my Spark and waited for them to connect. Once they did I tapped the Go Fly button and entered the app.
First thing I noticed was it skipped showing me the sensor states and went right to the app which is really uncommon in my experience so far. So I tapped on the GPS status at the top to see the sensor & AC status and everything appeared normal, compass was normal, flight mode switched from ATTI to GPS and looked normal.
I wanted to adjust my RTH altitude because I was surrounded by trees so I went to the AC settings and noticed that the RTH was at 0 (zero). I thought that was really odd so I tried to update it but it told me the update failed, so I tried again and again with the same results.
At this point I'm a little concerned and decided to check the max altitude and it also said 0 (zero), so I tried to set it back to 120 meters and it appeared to take so I returned to the RTH and tried setting it again but again it failed.
Now I'm a little more concerned and decided to try restarting the Go 4 app to see if it was just being stubborn. Once it restarted I tried to update the settings once again but still it wouldn't update.
I had the thought to check the sensor state under advanced settings and when I got there I saw something I had never seen before, wish I had thought to screen shot it but I didn't. The IMU was telling me basically it was unavailable and the indication bars were blank. Next I checked the compass, I don't recall if it said it had interference or was also just unavailable but I feel like it was the later.
At this point I decided that this spot was just not going to work to take off from so I moved into the grassy baseball diamond that I usually take off from.
I reset everything and entered GO FLY in the app. This time it showed me the sensor states as expected.
I went back to the advanced settings to check IMU & Compass and everything looked normal again.
Finally I went back to the RTH settings and the zeros were gone and my old RTH settings of 20 meters was back and the max altitude was set to 120 meters.
After seeing that everything seemed normal again I tried updating the RTH altitude to 60 meters and it took the first try!
I can't say for sure but I wonder if I wasn't really close to experiencing the yaw, compass, GPS errors trifecta that generally precedes a "flyaway".
So glad I tried to update the RTH today! Otherwise most everything looked normal to me and I would have typically taken off.
After three successful flights I went back to the same spot in the parking lot to see if I could reproduce the scenario but nope, everything looked normal. Typical!
Have you ever seen your RTH and/or Max Altitude set to zero?
Happy Landings! |
