KedDK
Flight distance : 1133038 ft
Denmark
I also find it quite annoying that the standard setting is Reset, i keep forgtting to check that, DJI please consider a change in this behavior.
It can happen at FW upgrades and will happen when you reset the camera settings and/or AC.
I have found that you can get it back on count, i do it like this:
Keep a few files (i keep one .mp4, one .JPG and on .DNG) rename to the number it should have had (same no for .DNG and .JPG, +/- 1 for .MP4).
Start up RC and AC, change setting to continuous, shut down AC, insert SD with renamed files and start up AC.
Take a picture and it should have the next number in you preferred count.
Not sure you need to start up AC without SD when doing the change, that is just how i know it would work. |
