LoSBoL
Flight distance : 666483 ft
You can get an Original 'reversed micro USB cable' from DJI, you could also use the bottom porton the remote to connect your device to with any micro-usb cable.
You can also use the short USB-C cable in conjunction with the small USB-C to micro-USB adapter, which you can just turn around to change the micro-USB orientation.
If the Nexus has problems connecting, you can try turning on the 'USB-debugging' in the 'developer settings', if you can't find the 'developer settings' in your device, a quick qoogle will get you up and running.
With the DJI Assistant you can:
-update and reset your firmware
-Calibrate the vision system
-Download your flightlogs
-Acces both internal storage and micro SD card for pulling of their contents.
And yes, you should be able to connect your remote to the DJI Assistant aswell, but there are some driver issues that DJI still has to resolve.
It's also good to take very good note of what's in the manual, which you probably haven't recieved with the drone. (the Quick start guide is not the manual...)
You can download the manual here.
