Cap0ne
Flight distance : 217077 ft
Romania
Samphoto Posted at 2018-5-22 08:36
Yes, corners are a bit soft but I don't consider that a defect. Most lenses, especially wide angle lenses suffer from this problem. My $1000 DSLR lens isn't perfectly sharp across the image unless I stop it down to F/8 which we can't do on the MA. It is easily fixed with a slight crop or, in my case, I don't worry that much about it because people aren't looking at the corners when it is on IG or FB or websites and I'm not printing them out large enough for anyone to really see it.
For me, the one I have is perfectly acceptable for what is effectively a $200 point and shoot camera.
You are right regarding the lenses being softer at the edges. But i doubt the sensor from mavic is using all the surface of the lens. It's like crop vs full frame on dslr.
Also, if that was the case, i think the image should have the same degree of softness on the edges. Mine is sharp on the left side and soft on the right one. Also the corners are softer on right than on left.
Anyway, compared to the first one, this is way much better I think just my pixel peeper side of me is bothered by this problem now |
