Labroides
Flight distance : 9991457 ft
fansa84fe8a4 Posted at 2018-3-21 20:15
No confusion as the video posted shows 15mm, 24mm, 35mm, and 50mm lenses, and those are the focal lengths and not corrected for the small sensor. Same as the lenses on the X5 series of cameras where a 45mm is the focal length of the lens, but apply it to the m43 sensor and it is a 90mm equivalent for FF. If the video posted the lenses as 8.8mm then the multiplier would be 24mm equiv. on a FF sensor. So the video should show 5.5mm, 8.8mm, and 19mm if they had meant the equiv. of 15mm, 24mm, 35mm, and 50mm which the video does not show, nor would they be indicative of the true focal length of those respective lenses shown.
As to DJI quality issues, out of 4 drones I have, all have had issues and two severe ones out of the box. If yours is perfect, I doubt if you've looked close enough or never encountered some software/firmware issues. Having focus wheels for the Inspires that do not even bolt up out of the box new, or a X5S camera with extra lens connection pins falling out of it when new from the factory is a bit much, not to mention crooked sensor alignment on two cameras, or magenta images due to a lack of a tint control for manual white balance for years.
If you go back to the original source, where this first surfaced, you see four lenses each with the word: Equivalent in small print under the large number on the lens barrel.
We'll have to see what gets released to the market but common sense should confirm what I said is correct.
And I've had no quality issues with my 4 pros.
They produce excellent results that satisfy me and some picky clients.
They've paid for themselves many times over. |
