DJI Thor
Flight distance : 13602 ft
Yes, please note that environment is significant to the flight distance, if there are obstacles and interference around, the range might not be too far.
So please try to fly in another open wide area, make sure that the antennas are unfolded on the drone, and the RC antennas are pointed correctly to the drone.
You can also check and select a channel with good quality, you can change the channel on the WiFi settings. See if it helps.
