This is really weird and needs to be addressed by DJI, hopefully it was on this last firmware update. Thank you for explaining the situation to us and I believe I will need to check my batteries prior to using them. I guess I need to put them on the charger regardless what the led lights are telling me.
RichJ53 Posted at 2015-5-10 23:38
This is really weird and needs to be addressed by DJI, hopefully it was on this last firmware upda ...
This just happened to me for the first time. I had a battery that was reporting 75% charged and I updated the my firmware using battery. Once the firmware update was done I had about 65% charge. I cautiously flew my inspire ~5ft off the grown to test out the new firmware and propellers. Exactly 1 minute into the flight the drone decided to land due to critical battery warning. Battery was now at 6%.
amccloud Posted at 2015-5-11 05:50
This just happened to me for the first time. I had a battery that was reporting 75% charged and I ...
did you top off your battery after the update?
I just finished my flight with the new firmware after topping off the battery. I got about 17 minutes total time with one flight of 8 min and one of 7min (TB47). I decided to let the battery drop the rest of the way from 18%. It only took about 3min to drop to 5% then landed.
(TB47) For the long version, see my posting... but the short version of some interesting new data...
At first, I got a failure alert...
Then, reseated the battery, and it flew fine.
Then, on investigating the "History", I see these amazing entries. Notice the contradictions...
Then, I look at other batteries history... no entries. And then I go back to my original battery with the bad history... and it now shows no entries, just like the other batteries.
Now I'm completely stumped. DJI, some assistance here please?
On another subject, I live about 8 minutes from the Roseville Bridge and fly there a lot. We should totally go flying sometime! I have my Inspire and my P3 arrives tomorrow.
had this same problem after updating the new firmware today (12th May 2015). Battery showed 33% and i initiated take off just to check that everything was fine. i was hovering at 5 feet when all of a sudden within less than 1.5 mins the aircraft showed only 7% and landed on it s own.
I tried the same thing with another battery that had 17% and the same thing happened.
It continues to seem as though the ONLY safe way to take off is with a battery charged to 100%. I have flown through multiple packs since the latest firmware/app updates and have seen no drops. Based on what I've read here I wouldn't dare to take off using a partially-charged pack.
@peterconquest3 I saw exactly those same errors and behavior. Swapped to a battery with 100% nothing in log. Swapped back to failed battery after charging and the errors in the log were gone.
Do we know if the battery really is "empty" when this alert is triggered or is it only the software that thinks so ?
Where did you store the batteries during auto discharge ... In the Inspire Case or in a ventilated area ?
I have my bird grounded for know (because of the battery problems) but as I yet again got the prompt to do a complete discharge / charge cycle from the pilot app after the latest update maybe this is the only thing I need to do to be able to have a safe flight ?
I would call this a bug - my experiences are it happens when you power on with a battery charged less than 65%.
Started with 99% on the TB48 flew a couple minutes down to 60%. Moved to a different location and took off again with the same battery maybe 60 minutes later. After reaching 30% I returned but before reaching my place it dropped within seconds from 28% to 7% powered off and made a hard landing...
The other incident was similar with 1 day in between. Took off with around 55% on a TB47 to practice a couple camera moves maybe 15m above the ground with battery warning at 30%. barely had time to get it back to the ground safely after the 30% warning signal - they drop within seconds from 30% to 8% and emergency landing/crash.
Different Firmware on the two incidents. It would be great if DJI could bring a firmware update so we can fly safe on batteries not fully charged (which is important at least to me flying in remote locations without access to power during the day)
Partly charged battery on first test flight after firmware update... battery gets to 53% and I get 'critical electrical failure' message. Bird just starts to land itself and in my rush to get her back, she goes down anyway - in real goony bird style. Luckly, nothing broken.
