DJI Susan
Hi there, ADS-B receiver has been installed in the aircraft of M200 series, which is used to receive the signal of the airplane. The aircraft will judge whether there will be the risk and decide to notify the pilot. At this moment, it only supports to detect the signal of the airplane which installed standard ADS-B OUT of 1090ES(RTCA DO-260) or UAT(RTCA DO-282)
a. If the aircraft is 180 seconds away from the airplane, the aircraft on the map will be in blue, and a warning prompt will pop up and then disappear.
b. If the aircraft 120 seconds away from the airplane, the aircraft on the map will be in yellow and a warning prompt will pop up and then disappear.
c. If the aircraft is 60 seconds away from the airplane, the aircraft on the map will be in red, and a warning prompt will pop up and not disappear.
