AlphaFlightNW
Flight distance : 784265 ft
WBY Posted at 1-25 03:00
I updated the Mavic 2 Pro aircraft with V01.00.03.00 using Assistant 2. However, I have tried to update the controller many times but it never completes properly. It goes all the way through the update of the controller to 100% complete, and a message in the bottom left corner that says it has been updated. However, when I go BACK to the Firmware Update status table it shows the current version still as V01.00.0200 and the button to UPGRADE to V01.00.0300. Help please.
So which way are you updating your controller, mobile device or Assistant? after getting this message, does it tell you to restart the remote? Typically if it does not prompt you to do so the update has failed, and not restarting the rc after update may cause some issues. Hope this helps |
