Vyborny83
Flight distance : 166014 ft
Czechia
King210210 Posted at 2018-3-24 22:03
correction: I am not sure if "abberation" is the correct term here, but in any case, if you zoon into the photo, (i.e. my face) you will see that it is very fuzzy and cannot make out the details. The same photo taken at same MP setting (12MP on my Sony camera) is about ten times sharper
When you connect the Spark to the RC, the only WiFi you will see is the one of the RC. I don't know whether there is a workaround to connect to Spark directly (while it is linked to RC) but this behaviour is completely normal.
As to your pictures. Have you tried to download them directly from the SD card ? Either take out the SD card itself or connect the Spark to your PC via an USB cable a check how the pictures look. |
