Labroides
Flight distance : 9991457 ft
djiuser_UVCvMNfFUzVw Posted at 6-29 12:16
Let me jump in this conversation with a similar question… I fly a Mavic Pro 2. For some reasons, sometimes (I don’t think it does it always), when I take off from a cliff (usually by the sea) and want to make the drone descend off the cliff, it won’t let me. It’s as if it sensed some non existent ground below, and if I keep the downward lever pressed, at some point it starts the landing maneuver (which is very unsettling). It’s not even about the negative altitude because because it stops descending far above the takeoff altitude…
Anyone has experienced this?
For some reasons, sometimes (I don’t think it does it always), when I take off from a cliff (usually by the sea) and want to make the drone descend off the cliff, it won’t let me. It’s as if it sensed some non existent ground below, and if I keep the downward lever pressed, at some point it starts the landing maneuver.
This has nothing to do with flying off a cliff.
If the drone could "sense some non existent ground below", it would happen anywhere, not just off a cliff.
But sensing some non existent ground below, is likely to be the issue.
It sounds like there may be a problem with the downward sensors.
Start a new thread and post the recorded flight data to have someone check to see if this is the cause. |
