(1) On the cam setting (the camera with a small gearing button), click on "plus" and you'll find "Format SD card".
(2) You cannot tilt upward. The 30° upward tilt is reserved for the gimbal to compensate the aircraft tilt position.
Ulysse Posted at 2015-5-8 00:19
(1) On the cam setting (the camera with a small gearing button), click on "plus" and you'll find "Fo ...
#2 is actually incorrect. There is now an option within the app to allow the gimbal to rotate up 10 degrees (I think it's 10, might be more, but it's definitely there)
Now we just need to to be able to go further than the 90 degrees down, please!
It would be very useful for certain shots, to be able to go further then the 90 - for artistic purposes, and avoiding the abrupt stop hitting the limit while moving the gimbal down.
