Os Ortega
Flight distance : 41148 ft
Panama
Mark The Droner Posted at 2018-4-4 14:40
It can be confusing, true. But the option is in case you'd like to have a max distance set. For example, if you want your max distance to be 100 meters, you'd enable it, and then set it for 100.
By not enabling it, you have no set max distance, which is to say your actual max distance is the limit of your control signal.
his last one makes a lot of sense, when I have it disabled I reach 502 m and this must have been caused by a telephony antenna thank you very much for the explanation now I understand |
