MAPilot
Punchbuggy Posted at 2018-4-8 23:28
Sadly David, that post just demonstrated to me that you don't really understand what ND filters do. I suggest you research more on what effect ND filters have in bright and reflective conditions.
And the argument that filters stress the gimbal motors is rubbish - well, at least partially, as it'll depend on the filter make. Hey, you get what you pay for. Just remember that the filter replaces what's already on there - it's Not an addition. So if the filter is built using similar light-weight materials as what DJI build their stock lens with, it should be like-for-like.
It seems that there’s a lot of agreement about using filters.
The gimbal will wear, with or without a filter on the end of the lense barrel. All else being equal, the one with less weight hanging on will have less wear after the same amount of use. The ring that you unscrew to replace with a filter has weight too, so if you want to minimize the load on the gimbal, it would be logical to remove it too; I don’t suggest doing so, since the ring protects the thread on the barrel.
If DJI did not expect filters to be used, why would they cut a thread into the lense barrel?
Whatever filter you put on, ND, CP, UV, etc., we’re talking about less than 1 gram, so you have to keep things in perspective.
Finally, I suspect there are other factors that affect the wear on the gimbal, such as accidentally leaving the gimbal cover on when powering up the drone, or handling the camera while the drone is powered up.
I think my original question (OP) about installing filters has been answered. |
