Videos Not Visible on Editor Application
9617 6 2018-4-7
mylens
Can anyone tell me why my videos are not showing up on the video editor on the DJI Go 4 Application.  My Mavic Pro is recording the videos, but they are not showing up on the video editor.
Thanks, Mike
2018-4-7
DJI Thor
Flight distance : 13602 ft
Mike, please check if you had enabled cache when video shooting in General Settings. If this option is off, the cached video will not show up on the editor. See if it helps.
2018-4-7
mylens
DJI Thor Posted at 2018-4-7 17:54
Thanks for your help.  Are you talking about checking the general settings on my iPhone or in the Mavic settings?  I could not find any video settings on my iPhone.  The videos were appearing, and then all of a sudden they stopped.  I figured it was a software update, but I couldn't figure out how to fix it.
2018-4-7
DJI Thor
mylens Posted at 2018-4-7 18:33
Sorry, I should've made it more clear. They are the settings in the DJI GO 4 app. Please connect the drone, RC and mobile device, launch DJI GO 4, Go Fly, upper right icon, General Settings, Cache During Video Shooting. Ensure this option has switched on.
2018-4-8
mylens
DJI Thor Posted at 2018-4-8 02:24
Thor,
I just wanted to say thanks!  I was able to see where to make the adjustment.  While the Video Cache seemed to be on, my Video Cache Memory was limited to 2GB.  I suspect I may have reached my limit, so I also cleared my Cache and increased my limit to 16GB.
Thanks again for pointing me in the right direction!  Problem solved!
Mike
2018-4-8
DJI Thor
mylens Posted at 2018-4-8 18:10
Thor,
Mike, thank you for your update and glad to know that you found out the issue and got it worked. If any further issues, don't hesitate to ask.
2018-4-8
HeKToN
I found a way to put any video I want to be in the editor. You have to move the video in DJI/dji.go.x/DJI Albums. When you move it you have to rename it anything but the name should start with org_ .
Thanks
2021-7-21
