Pilot H
Flight distance : 209764 ft
Well I can answer one of your questions, Does the camera normally get hot (body and lens) yes, this is perfectly normal. Infact, DJI often advises using a small fan pointed at the camera while using the flight simulator to keep the camera cool, (when you're flying, the air will keep it perfectly cool). Some people use laptop cooling pads to keep it cool for the simulator, personal choice. As for the SD cards, I'm not entirely sure, if I can track it down again, I know a site that lists supported SD cards. I'll send you the link if I find it.
Have a good one, hope you figure out your SD Card issue.
Only the prettiest of flights and calmest of weather to you.
Good luck, Pilot H.
