OTG for spark, is it back in DJI GO 4 _ 4.2.12
123
17598 109 2018-4-16
Blellow
Flight distance : 1311056 ft
Rechecked everything is working with spark and Nexus 7 1st generation. Yippie!  Thank u all!
2018-4-26
SuperMario5
Flight distance : 131070 ft
Mexico
EU user on Samsung A5 v2016 works fine. DJI THX
2018-4-26
Charliejspark
Flight distance : 286654 ft
Hurray downloaded in UK.  Goodbye 4.1.15
2018-4-26
rimza
Flight distance : 3307 ft
Brunei
Yep updated it, will try it this weekend. Hope it is all fine.
2018-4-26
Zamskie
Philippines
M1dn1ght N1nj4 Posted at 2018-4-19 09:04
I assume you didn't get it yet?  If you did, does it work?
It works. I already have mine
2018-4-27
Zamskie
Philippines
2018-4-27
Zamskie
Philippines
Zamskie Posted at 2018-4-27 00:06
I'm using this cable with Samsung S8+ with DJI Go v4.2.12
2018-4-27
ManuelV
Flight distance : 83051 ft
OTG working fine on a Spanish Honor 9 (Android version 8.0.0). No problem changing from 5.8 to 2.4. Time to go flying.
2018-4-27
Tridiver
Flight distance : 4459344 ft
Downloaded the update.  So with the cable attached, I'm supposed to go into the settings mode and turn off the wifi??  Is this right??  I did that and didn't get a signal from the RC.  Any help??  Thx  Bolton
2018-4-27
TsukoYomi
Flight distance : 23422 ft
Philippines
Vyborny83 Posted at 2018-4-17 10:11
Ok, so I've tested the newly released DJI GO 4 and here are my results. I've tested DJI GO 4 4.2.12 build 557 with a Spark firmware 01.00.0900. DJI Assistant claims this is the newest firmware.
First the good news, OTG really displays the essential flight data again. Now the bad news, I can't see the the info about the WiFi channels (how much interference there is for each of them) and I am unable to force the RC to switch between the 5,8 GHz and 2,4 GHz band. It doesn't matter whether I use the cable or go on WiFi only connection. It simply doesn't work at all. The only way how I'm able to see it is when I reset the WiFi of the Spark and connect to it directly by phone. It connects via 2,4GHz and I can see the channel info just fine. I suspect it has something to do with the fact that my phone can't use the 5,8Ghz band but we will need more people to test it out. I'll include some screenshots below.
same here... no channel data... well since 4.2.8... and can't change to 2.4ghz...
should i reset my spark? (i mean unlink it from my rc then re link again for 2.4ghz?)
but still no channels showing if it's good or got interference...
PS in 4.2.8 auto channel i can switch from 2.4 and 5.8.. now in new version stuck at 5.8
2018-4-27
Vyborny83
Flight distance : 166014 ft
Czechia
TsukoYomi Posted at 2018-4-27 06:05
Well, I wasn't able to find a solution so far. Here is what I tried : downgrade DJI GO 4 back to 4.1.14,  reset the Spark to factory settings via DJI Assistant 2, reset the link between the Spark and the RC and pair them again (many times). After that I tried to downgrade the Sparks firmware, unfortunatelly, the oldest version I can see is .701, up untill now I used firmware .600 but I can't find it anywhere anymore and when I asked for help the DJI Support they told me that there is no bug in the App or firmware and I should send my Spark for repairs as it is probably broken ... when I argued that it all worked fine till I upgraded the App and the firmware and asked for an access to the older version of the firmware ... they didn't even bother to respond anymore and since I received a satisfaction survey yesterday I believe they closed my case without even trying to help me ... really dissapointed with their support.
Btw, could you try to break the link between the Spark and the RC and connect the phone directly to the Spark ? That's the only way how I can see the channel info, unfortunately, since my phone does not suport 5,8GHz I can't try switch the bands this way but since I am not the only one, it is clear that DJI indeed has some problem with their SW ...
2018-4-27
manolism
Flight distance : 53035 ft
Greece
Today i installed to my android phone (xiaomi note 4A) the latest version 4.2.12 of Dji GO 4 but unfortunately otg cable it still doesn't work, the only action that is doing it's to charge the controller...
2018-4-27
derider
Flight distance : 2760853 ft
Denmark
Got the update Go 4 4.2.12 yesterday at my Samsung S7 Edge and the OTG works well - That was a very nice update from DJI Thank you.
2018-4-27
Elettrone78
Flight distance : 2840512 ft
Is it working on the Crystalsky too?
2018-4-27
Blellow
If u r stuck in charge loop, power down everything and try again following the specific procedure.
2018-4-27
derider
Denmark
Elettrone78 Posted at 2018-4-27 10:26
The CS is still running Go 4 version 4.2.8 which don't have OTG at the Spark - We will have to wait for the CS to be updated before we can use OTG together with the Spark.
2018-4-27
manolism
Greece
Blellow Posted at 2018-4-27 10:59
Because you mention about ''specific procedure'', i start thinking that maybe i am doing something wrong!!! And this was the problem....i didn't plugg the otg cable to the RC device but to the phone. When i put the otg cable into the RC everything works fine!!! At last otg cable is working!!!
I want to thanks S-e-ven because after a fast search i find this post of him:
S-e-ven Posted at 2018-1-28 05:47
The main point:
The otg adapter needs to be plugged into the RC
Not in the phone
The phone is the USB on the Go device here.
Like a USB Stick is for a phone.
and that was the solution to this problem!!!
2018-4-27
Wagner5
Flight distance : 65328 ft
Junior SBC Posted at 2018-4-16 18:17
Good news! Thank you for sharing... But, here in Brazil is 4.2.8
mine got updated today!
2018-4-27
djiuser_hXGFjTkofHWq
Flight distance : 14528 ft
manolism Posted at 2018-4-27 12:13
Could you describe the specific procedure.  I have 4.2.12 installed.  I tried a cable but if I turn off WiFi on the phone the connection drops.
How can I tell if I am working over OTG?
2018-4-28
Gabriel_Spark
Flight distance : 612749 ft
Mexico
derider Posted at 2018-4-27 09:38
How did you manage to make it work? I also have a galaxy s7 edge and I have not been able to install it from DJI GO 4 4.1.15 version, I get a network connection error when I start the program, I have internet and it's not the problem I just do not want to connect .
2018-4-28
Blellow
1. Turn drone on wait for beep.
2. Turn on remote wait for it to link with drone.
3. Turn on tablet in airplane mode and plug wire into tablet, then remote.
4. Prompt on tablet should pop up asking to start dji app.  Click yes.
2018-4-28
derider
Denmark
Gabriel_Spark Posted at 2018-4-28 19:13
My S7 Edge had the  Go 4 version 4.2.8 and the upgrade was done from this version to version 4.2.12 with no issues.  About 3 weeks ago I did use the DJI GO 4 4.1.15 version but upgraded to 4.2.8 to be able to use my phone and Mavic air also. The GO 4 version 4.2.8 was much more stable than the previous GO 4 4.1.18 (but no OTG and its longer range benefits).
How did you do the upgrade. Did you uninstall the Go 4.1.15 before upgrade to GO 4 Version 4.2.12 and have you tried to reboot the S7 after uninstall of the old version?
2018-4-28
manolism
Greece
djiuser_hXGFjTkofHWq Posted at 2018-4-28 18:09
-  Turn on drone
-  Turn on remote and wait to link with drone
-  If you use otg adapter, as you can see in the picture, you should plugged into the remote.
-  After that you will see on your phone a pop up window asking to start dji app, you select ''yes'' and you are ready for flight!!! Wifi in that case must be off otherwise your phone is linked with the remote without otg cable.
2018-4-29
S-e-ven
Flight distance : 5922034 ft
Thailand
manolism Posted at 2018-4-27 08:59
use the OTG cable 'upsidedown', please.
The RC has to charge the phone
2018-4-29
S-e-ven
Thailand
ok, you found it yourself
So ignore my last post before this one ;-)
2018-4-29
S-e-ven
Thailand
Only when you have a RC connection but aren't using wifi! ;-)
2018-4-29
S-e-ven
Thailand
Blellow Posted at 2018-4-28 19:30
Starting the drone is for me the last thing, I do.
For getting the Device and RC connected, via cable, there is only
1. Start RC, wait till LED red
2. plug 'exit' side of USB OTG connection in phone
3. plug 'entry' side of USB OTG connection in RC
... needed. App shows 'connected' then already (connected to RC!)
Start Spark, wait till LED on RC turns green, App shows 'go fly', go and fly
2018-4-29
manolism
Greece
S-e-ven Posted at 2018-4-29 02:08
Everything is ok!! Thank you!!
2018-4-29
ortispark
Flight distance : 265876 ft
Update on version12 with moto e4 Android  And otg câble:  first flight yesterday , total distance 1.8 km , 50 m altitude, ni issue, vidéo réception without any issue, no fault messages
Now  a happy customer
2018-4-29
djiuser_89K57DdR2ELs
After the update my spark wont connect with otg cable now. Can anyone help please?
2019-8-25
123
