Nigel_
Flight distance : 388642 ft
betreedcam Posted at 2018-5-5 08:10
it seemed like right at the end there the controller also started beeping and may have lost signal (with a flat battery on the controller)... so then maybe that is why we couldn't manually get it home? He had thought it had charged all up - didn't check but obviously the plug in didn't work (Cambodia has dodgy power strips)... but he neglected to check if it had charged..
ANd yes, beginner mode would have been best! it was just such a beautiful morning!!
The flight starts with 94% battery, I guess you made a short flight or hover first and it was fully charged to start with which would be OK, but if not then starting the day at 94% is not good. Always start the day at 100%.
The beeping at the end was quite likely obstacle avoidance giving a warning, I can't see that in the logs but it seems likely since you descended through a tree. If you replay the flight in the Go App then you may understand better, and turn on the controls display so you can see where you were making the mistakes.
The log appears to stop due to bad reception - there were probably too many trees in the way, although I can't be certain.
We all have to learn, most of us learn from our mistakes, unfortunately mistakes with a drone are quite easy and can end up expensive, especially when you cant see it! |
