Bekaru MP UAV
Flight distance : 15513100 ft
South Africa
hey,
it is inconsistant but some things i notice (although as i say inconsistent) that when most of the image in view is generally darker (subdued) and then bright bits come into view (like reflections on water or white sand in between long grass or the white stems of water reeds) then that seems to set it off.
From that point it will sometimes come right but more often goes from bad to worse and soon enough i cannot view my image at all anymore.
other times in the exact same place it works without glitch -
i tried various devices - recently one from the dji list samsung note 4 and the problem was consitent and worse with that device than it is on my existing phone.
Some times it happens much of the time - other times it happens less and other times hardly much at all.
Mostly close range - sometimes at a distance but that would be rare - more often when close - in fact i recently did some close shooting and could not believe that for the first time in ages i was able to with image blurring out.
usually if it happens i will notice very soon after launch - sometimes i could have flown for a bit without issues and then all of a sudden it kicks in.
Our days are pretty consitent at between 20 - 27 degrees, mostly around about 24 or so. The issue is not worse or better, that i have noticed, with varying temperatures.
humidity - thinking back, i do not think so - i could have the issue on any type of day and i could have no issue on an type of day.
I tried my friends RC with my drone - same problem
thanks for your time to consider this issue.
