r00tb33r
Hey all,
I've got a P3 Pro here that's in a bad pickle. A friend recently updated this P3 Pro to the latest firmware using the DJI app, but after the firmware update we had RC signal problems, despite many RC pairing attempts with the button on the side of the drone (seemingly successful, according to the app anyway, but still complained of weak signal or disconnected). Can see the feed from the gimball camera, but won't do anything else, can't take off or fly, flashed yellow LEDs in the back. Drone was fine before the update and we certainly regret updating it.
So naturally after all that failed I tried downgrading the firmware back. I downloaded firmware v1.07.6 from http://phantomhelp.com/Mobile/Ph ... al/#FirmwareArchive and placed the .bin file (not the .zip archive!) in the root of the SD card. I started up the drone and the RC without the SD card, and once initialized I inserted the SD card. The drone started making quiet chirping noises and 10-15 minutes later had solid RED lights on all four corners, that's a failed firmware update/downgrade from what I understand. I tried a few more times, including removing the log files from the SD card per suggestion I found online, nothing.
On last attempt it became even worse. Now as soon as the drone is powered on it's beeping loudly like a smoke detector or a car alarm, and won't stop, no lights on the corners. I let it sit like that beeping in the garage for 2 hours with the .bin file on the SD card, but no change. Is it bricked? Any method of recovery?
Here's what it looks and sounds like:
https://nofile.io/f/e8f8Cf0bpB0/MOV_0202.mp4
Any insight is appreciated. Thanks in advance!
