Any idea of what is happening guys? Crashed my drone doing Helix in a tree, nothing broke, propellers are good and all seems to be fine but that errors popped up and won’t go.. can I try anything?
You should be able to hear it very clearly when it's cooling the AC electronics. Overheating might be due to not spinning and if so you need it repaired.
FlyDK Posted at 2018-4-21 02:54
You are correct!! It is not working.. quite like a log..
For sure something else could be wrong. Regardless if the CPU cannot be cooled you cannot fly it. Just like if you have a computer where the CPU fan and heat sink don’t work. You will just make it worst. Send it in.
