djiuser_Ncp5glVyYOLh
SAME PROBLEM! WHAT HAVE YOU DONE TO THIS DRONE?
The drone will shoot frames manually in DNG & JPEG but the panorama mode fails to record the DNGs and JPEGs.
All that I get on the SD card is the rubbish low resolution badly stitched jpeg.
This indicates to me that all frames are being captured, then deleted.
I am experiencing the same problems, with the SAME SD cards that I have always used!
These cards are listed in the mini3pro specs on your website at https://www.dji.com/au/mini-3-pro/specs
SanDisk Extreme Pro 64GB V30 A2 microSDXC
SanDisk Extreme Pro 256GB V30 A2 microSDXC
I shoot panoramas in RAW+JPEG (I only use the Raw files, but the drone shoots the jpegs in order to (badly) stitch a low resolution jpeg panorama.
Previously, the drone would store the DNG + JPEG files on the SD card, now I discover that only the badly stitched low resolution pano is saved there.
It is as if DJI have totally killed the DNG panorama feature.
Because I had some urgent jobs and DJI locally couldn't solve the problem, I bought a new Mini3Pro (drone only), set it up today and made a test.
Here is an example of a 360° panorama shot in DNG frame format, converted to Tiff files, stitched in PTGUI Pro then converted to a virtual tour online.
Resolution is about 260 Mpx and I hope that you can't see any stitching errors!
https://www.hiddenmelbourne.com.au/camberwell-town-hall/
PLEASE SORT THIS OUT URGENTLY
Barney from Melbourne Australia |
