ultrasonic sensor error
123Next >
16501 88 2018-4-22
skyenya
Turkey
Got "ultrasonic sensor error land immediately" - control kept working - landing normal.
How to solve this issue?
2018-4-22
DJI Susan
Hey Skyenya, has the drone been involved in the crash or hard landing before? If not, please do not mount any accessories and refresh the firmware to see whether it helps.
2018-4-23
trabin
Flight distance : 758579 ft
Poland
I have the same problem for a week. The drone never had a hard landing
2018-4-23
Eric13
Flight distance : 13982031 ft
Are you sure it said 'ultrasonic' and not 'infrared'?
The latter is being discussed here:
https://forum.dji.com/thread-136473-1-1.html
2018-4-23
trabin
Poland
yes i have info "ultrasonic sensor error land immediately"
2018-4-23
skyenya
Turkey
I have mounted device for fishing)
2018-4-23
trabin
Poland
I have still problem with ultrasonic sensor error :/. Only once was everything ok a few days ago.
Today i have again "ultrasonic sensor error land immediately"
2018-4-29
trabin
Poland
DJI Susan Posted at 2018-4-23 03:21
I refreshed the firmware and nothing. I did downgrade and upgrade firmware and nothing. I have still "ultrasonic sensor error land immediately" when i take off.  My drone never had hard landing or crash.
2018-5-1
fans0a7b45f2
I too after the latest firmware update have been getting that same error. I have calibrated  imu and compass via dji go app (flight after gave the same error.). After that  I have calibrated the sensors via dji assistant app, and now I'm waiting for the weather to get a bit better to try and fly again. Hoping in no error after sensor calibration... If that doesn't work, I'll try refreshing the firmware. After that I think I will dismantle the drone and try a thorough cleaning. Last resort is to send it to assistance '-_-. (phantom 4, 1yr old, first battery). Did not have any hard landings or crashes.
2018-5-2
Black Panther
Flight distance : 407113 ft
I got the same error on a previous flight.  I did a full calibration and haven't seen the error message since.  FWIW
2018-5-2
trabin
Poland
fans0a7b45f2 Posted at 2018-5-2 03:52
I calibrated vision sensors and still nothing :/  I hope that my drone will not suddenly fall
2018-5-2
Gallanonimek
Flight distance : 159226 ft
Poland
Hi, I have the same problem with the new firmware. I have already tried calibrating compass, imu and VPS. After that, I uploaded the previous version of firmware, for now, I didn`t see any error connected with an ultrasonic sensor.
2018-5-3
DJI Susan
trabin Posted at 2018-5-1 02:18
Received with thanks! This issue has been reported to our engineers, they are working on it. I'll keep follow up as well.
2018-5-7
DJI Susan
Hi All,
Sorry for the troubles. Our engineers have been aware of the warning of ultrasonic sensor error, and they are working on it. We'll keep you updated if there is any news.
Thanks for your patience and understanding.
2018-5-7
Dutch Locutus
Flight distance : 96381 ft
Any news about this issue?  I experience the same Ultrasonic sensor  error since I updated the firmware last week.No effects on the behavior of the phantom, but I don’t dare to fly with the warning lights on within 1-3 minutes of each flight. So I am grounded till there is a firmware solution.
2018-5-9
trabin
Poland
I uploaded the previous version of firmware. I have tried calibrating compass, imu and VPS and now I have big problem with descend. When i put stick down on max, drone not descend or descend is very very slowly :/ I am grounded too ;(
2018-5-12
KedDK
Flight distance : 1133038 ft
Denmark
trabin Posted at 2018-5-12 02:05
"I am grounded too ;("
I would say you're the opposite ... Sorry.
If any, the only thing you would have needed to try calibrate was the VPS system.
Have you tried a factory reset followed by a refresh of the current version? it sometimes need to be repeated to make sure all modules has got it.
Do you still have this Ultrasonic error too?
2018-5-12
trabin
Poland
KedDK Posted at 2018-5-12 02:19
In V02.00.0106 i don't see ultrasonic sensor error. I did not try factory reset. I have only files flying log data from today flight. I 'don't have txt files ;(  so I can send only fly.dat files
Today's flight and problem with descend
In V02.00.0700 flight logs with ultrasonic sensor error http://www.phantomhelp.com/LogViewer/IFTNF919DRNDDYL0ZOAR/
2018-5-12
KedDK
Denmark
trabin Posted at 2018-5-12 03:17
Today's flight and problem with descend https://www.youtube.com/watch?v=zqvmEvwuNKE
Was your descend problem also present before the firmware downgrade?
It does look strange in that flight record recording but there is no chance to see if it would be caused by the sensors seeing something that stop it from descending.
As far i have noticed i have had the Ultrasonic error once on the P4P, it popped up even i always keep all sensors disabled due to the unbearable beeping and too many times the sunlight has stopped the aircraft from moving the direction i want it to.
Still recommend trying the factory reset and a reflash of the AC.
2018-5-12
trabin
Poland
KedDK Posted at 2018-5-12 21:29
Hi. I have a problem with descend on old firmware only. I flew a few days ago before the IMU calibration and it was the same situation :/ In the latest version of the firmware I have only an ultrasonic sensor error
2018-5-13
trabin
Poland
I returned to V02.00.0700 firmware and I have still "ultrasonic sensor error" but I've no problem with descending. I hope this is a software error, not hardware.
I have last question. Can I fly safely with this error?
2018-5-14
928Estates
Flight distance : 453346 ft
I keep receiving the same error message and I also never had a rd landing or crash. My drone is in pristine condition. Despite the error and solid red lights, it flies perfectly fine and I can land it smoothly back on the take off point. I have never tried to see if it would slow down a too fast decent, as I always land it softly with the transmitter.
2018-5-18
trabin
Poland
Do you have any new information about ultrasonic sensor error or i must send my drone to service?
2018-6-1
Phantoman
What device are you using? Ios or android? When I use my ipad and ascend above 10m I get a "downward vision sensor is abnormal, land immediately". I descend back below 10m and let it hover for 10 to 60 secs the lights start flashing normally. When I use my Galaxy S8+ I get the ultra sonic sensor error. Again when I descend back below 10m, the lights will eventually start flashing normally. Other than that the drone flies perfect. I've only had my P4 for a week. It's a refurb I bought from the Dji store.
2018-6-3
trabin
Poland
Phantoman Posted at 2018-6-3 18:04
I'am using android device. I get a message about 10 seconds after the climb.
2018-6-4
trabin
Poland
Today's flight http://www.phantomhelp.com/LogViewer/BBCN84K86N5C6U4ZSJTR/
4 days ago http://www.phantomhelp.com/LogViewer/Y9VXV23ITLOMTSN9FHC1/ 23 May 2018 http://www.phantomhelp.com/LogViewer/4QJS1JREZ1CI09B5LY0W/
15 May 2018 http://www.phantomhelp.com/LogViewer/M9WTJ24EHKQIIRP53HDX/
The problem has occurred since March :/
2018-6-5
Jeff Millard
Flight distance : 503635 ft
Please make sure both your aircraft AND remote controller firmware are up to date. I was getting the Ultrasonic Failure land ASAP message almost every flight for a couple months. Kept the aircraft updated, but missed the update to the remote. After I updated it, the error stopped. Verify all of your firmware is current just to be sure.
EDIT: update, it did not stop. I’ve gotten the error message again.
Jeff
2018-6-5
trabin
Poland
Jeff Millard Posted at 2018-6-5 10:45
Jeff
I have current firmware. Overall status "Latest Firmware"
2018-6-5
Jeff Millard
trabin Posted at 2018-6-5 23:00
Did you compare the website to the controller. That message from the controller was the same with me, but there was an update on the website that was newer than what was on the controller.
Jeff
2018-6-6
trabin
Poland
Jeff Millard Posted at 2018-6-6 01:32
Jeff
Can you tell me how to do it?
2018-6-7
Jeff Millard
trabin Posted at 2018-6-7 01:28
From the Downloads page HERE (this is for the Phantom 4 Pro) compare this rev to what is on you controller. Using the Go 4 app under settings about, you can find the current firmware on the RC. The instructions are right below the firmware on the Downloads page.
Jeff
2018-6-7
Phantoman
Current RC firmware is 1.9.3. Mine is up to date.
2018-6-7
trabin
Poland
Phantoman Posted at 2018-6-7 05:42
I have 1.9.3 and today I have still problem with ultrasonic sensor error
2018-6-7
aCiDeViL
Portugal
I upgrade today and now I also have this problem.
I am sure this is not hardware problem but software, my drone was perfect before firmware update.
I never crash, and this message only shows sometimes, not always but when it show he don´t have any impact on how my drone fly.
I HOPE DJ FIX THIS IN NEXT FIRMWARE.
2018-6-22
Jeff Millard
aCiDeViL Posted at 2018-6-22 11:59
Please compare your remote controller firmware Rev. to the firmware available on the P4 downloads page. I was getting this error almost every flight. Since updating my RC firmware I have stopped getting the Ultrasonic Sensor error. YMMV.
Jeff
2018-6-23
aCiDeViL
Portugal
I have last version.
This problem shows exactly after update, calibrate sensors, IMU and leave to fly.
2018-6-23
trabin
Poland
I have still ultrasonic error with every flight. I will send the drone to service. I have no choice because the problem has occurred since March.
2018-6-23
KedDK
Denmark
aCiDeViL Posted at 2018-6-23 05:21
[view_image]
The error in the posted picture is not the one reported in this thread (ultrasonic), the one in your pic simply tell that there is to dark for the vision sensors to work.
I am not saying you don't have the ultrasonic error, just that the above is more a warning than an error.
Fly safe.
2018-6-23
aCiDeViL
Portugal
KedDK Posted at 2018-6-23 11:48
Hi KedDK.
Please the read the post before my.
I am answer Jeff.
2018-6-23
Aardvark
Flight distance : 384432 ft
aCiDeViL Posted at 2018-6-23 14:18
Hi KedDK.
I am answer Jeff.
Your aircraft and RC firmware are the latest versions for the P4P, from the release notes:-
Phantom 4 Pro/Pro+ Release Notes
http://www.dji.com/phantom-4-pro
Copyright © 2018 DJI All Rights Reserved.
Date : 2018.03.08
Aircraft Firmware : V 01.05.0600
Phantom 4 Pro Remote Controller Firmware : V 1.4.1.0
Phantom 4 Pro+ Remote Controller Firmware : V 1.3.6.0
2018-6-24
123Next >
