If you have the aircraft is locked error and your firmware is up to date then the app (dji go 4 apk) is broken. I found the work around which is using the older version of the app and just did the database updates only. Get the apk here. It does require you to install from untrusted sources though as it is not in the google play store. https://www.apkmirror.com/apk/dj ... droid-apk-download/
Jugglemstr, Please GO and Copy/Paste on all Forums like you usually do, dont only start one here its not enough, go around telling everyone please that we found the Solution, do us a favour dude, be our messenger ! Please !
How about you grow up? I only posted the fix in posts that didn't have it posted. I never took credit. So stop being a keyboard warrior and enjoy your drone.
judgemstr Posted at 2018-4-29 12:02
Take a Coffee Mate, It will serve you good.... why so Serious ?
Hello Juggle, did you go around the forums like I told you please ? We need more advertising, you can do it, you have time to waste. Cheers ! Thank you.
Thanks for your sharing. Please note that our engineers are working on that. Please keep us updated, if you have anything news or find any problem.
DJI Elektra Posted at 2018-4-29 18:52
Have a Good Day. Always Thank You for Your Support.
Bought a spark today......device locked with the actually Android Gofly App...With Downgrade - it works. Please debug it!!
Jugglemstr is the Guru of Software/Programming and IT Hardware, He specialises in Spacecrafts and Satellites Engineering at Space Agencies, he will Solve Anything !
Ask him anything, he will solve in Few Minutes or even Seconds !
