James3342
I'm new with the Mavic Air and having some troubles with the intelligent flight modes.
1. When trying to use "Circle", I'll draw a box around the item to circle, press the GO, it counts down, and nothing happens. If I fiddle with the drone position enough, it will eventually work. Is there a minimum height or distance I need to know?
2. Same thing with Rocket - it will sometimes work, sometimes I have to try a couple of times.
3. If I am in manual exposure mode and go into one of the intelligent flight modes it seems to go back to AUTO. Is this correct? Or does it just remember which mode you were in from the last time?
4. Any place that outlines each of the intelligent flight modes and shows a tutorial on using it? Like, what's the difference between "Point of Interest" and "Circle"?
Thanks in advance!
James
