Firework Video Capturing
1046 3 2018-5-5
EricMe
Flight distance : 122900 ft
Malaysia
Hi All,
I'm planning to use Mavic Air for firework video capturing. Can anyone share sample video, experience and best setting to capture best effect ?
1. Best drone setting on video and photo capturing
2. Drone height
3. Better to catpure from the top or side way
Thanks in advance.
2018-5-5
Oranges
Flight distance : 458356 ft
Malaysia
Hello,
I've filmed with a Mavic Pro, but it should be the same if not better with the Air (higher bitrate).
I'd recommend going with a higher ISO (1000+ perhaps) and make sure focus is at infinity (or far away) . Framerate is up to u whether u want crisp shots or cinematic feel
Chances of fireworks hitting the drone is slim, i've seen gutsy pilots who fly through firework shows, ending up with incredible footage.
U can circle the fireworks, fly backwards at an angle, pan down while flying up ( its all up to u)
Here's a quick test I did on Chinese New year in my hometown. Footage wasn't the best, Should've filmed in a higher Framerate to avoid the 'flares'. Color was slightly off too (on the warm side as I left my temp at 5800K (should've cooled it down a bit)
2018-5-5
EricMe
Oranges Posted at 2018-5-5 21:26
Hello,
Thanks for your sharing. The video looks not bad but just firework is not that grand and as what you shared, probably to adjust high frame rate to avoid 'flares'..
2018-5-5
DJI Diana
Flight distance : 2408 ft
Hello,
Nice video, thanks for sharing.
2018-5-6
