Compass Problems
jabokennel
Flight distance : 251142 ft
I am not able to get my compass to work. Every time I start up-, I get compass error, and attempt to calibrate. It will go from yellow to green in the horizontal position, when I attempt to go to the vertical position, it never goes back to yellow, and when rotated, it goes red. At that point my display says failed. I have attempted this more times than I can count, with the same issue. I have tried it in the middle of a 40 acre field and still no go. A couple of times, I rebooted the quad, and it says good to go, only to fly for a couple of minutes, and then I get computer error. I have performed the advanced IMU, and no help. Please some one HELP me. I am ready to give up on the P2P.
2015-5-11
gurnpj
Flight distance : 103609 ft
Make sure you are not around any cars or other big metal structures. It also helps to have your phone or other devices on airplane mode during the calibration process. Be sure your firmware is up to date. The more secluded you are away from buildings, power lines or anything else that could cause interference the better off you will be. Hope this helps.
2015-5-11
jabokennel
What do I do if I calibrate in a large field, then go to a subdivision where calibration is not able to be done?
2015-5-14
rickyc31
Flight distance : 1078760 ft
jabokennel Posted at 2015-5-14 22:58
What do I do if I calibrate in a large field, then go to a subdivision where calibration is not able ...
I never had calibration issues until my drone was repaired. Now I cannot calibrate it. It will say ready to fly, home point set, but when I try calibration, just like you described, it fails. 2nd time unit was returned was for this, just got it back last night, same problem. I am calling today, if I get any helpful info, I will share it with you..
2015-5-14
