HereForTheBeer
Flight distance : 5381368 ft
Schmooit Posted at 12-23 03:24
Hi chap yes that is possible but is very very very slow, the Phantom, spark, and all other mavics have had this feature as an option on the custom buttons, once you have used it you will find it very handy.
Either during a video or whilst landing for safety purposes too, the ability to quickly flip the camera down to check what's beneath you and then flip it back up is a must, using the scroll down feature or the screen is slow and cumbersome and is designed for use while filming (factoring in changing the gimbal settings to slow it down further to get better filming results and its even worse!)
I think they intentionally leave things like this out. Lot of things Mavic Air could be better off with having added and it is perfectly capable on hardware and software level but DJI ignores I think they do it to artificially do it to make a reason for next gen or to further artificially segment higher tier.
like reducing the charging current on the controller so not killing the battery of the RC when using android, quiet props, digital zoom slider, pick the live view quality settings, dual band mode, uplink v downlink signal meter to know if controller or the drone having signal issues, camera pointing center and down function, faster GPS mode, voltage read out next to the battery, set custom low vs critical battery, custom days to discharge option (right now set to 10 days means is a built in programable timer), |
