HedgeTrimmer
3-D Posted at 2018-5-15 07:26
TRUTH. She is probably the only one that would be able to get me to do that.
I was fine knowing that GPS wouldn't be great. I knew that it would be only line of sight, and i was "only going out to do a POI, then back in." I didn't think about the fact that the compass would be affected. Lesson learned. Lucky for me it wasn't a very expensive lesson.
In picture you attached it shows a metal railing just outside sliding glass door.
Did your room, where you flew from have same metal railing just outside sliding glass door?
If yes, it is likely made of steel. As high as railing looks, your drone may have passed with in 1-1/2 feet of metal railing. Which could have briefly effected drone's compass.
Effected drone's compass as drone flew from still air to disturbed air (aka changing winds, down/up drafts, etc.).
From the following post LINK, this picture shows effects of a steel guard rail with far less steel.
The two lobes (increased field strength) comes from Smartdevice passing over steel guard rail.
If you are still at hotel, you could bring up CellPhone compass and try passing it over room's safety railing, to see if compass deviates from direction pointed to inside room.
