Marsofearth
Flight distance : 89829 ft
Hi everyone.
I am coming to conclude that my Mavic Air is a lemon. I have less than 50% success rate with flying it. What do you mean 50%?
Well.
- Constant compass calibration. Start Mavic Air(MA) and be asked to calibrate compass. Calibrate compass. Put MA down, whoops be asked to calibrate compass. Move MA to a different location where I have never had problems with compass calibration. Calibrate compass. Good, start to flight, Warning! Compass Calibration!! Calibrate compass again. Okay seems good. Fly.
- Gimbal moving jerky. Sometimes the gimbal moves in jerks, or looks as if it's stuck. Sometimes when I bring the MA back to me, with gimbal down, the gimbal will not go back up. When I land the camera is facing straight down, it will not move up. Turn MA off, and it feels as if camera gimbal is stuck then, loose... no problems... This happens 33% of my flights.
- Video is noticeably soft in upper right corner to about 1/3 of corner frame. Sharp from center to bottom left corner... Even when looking straight down on a parking lot... Then other times, no problem video is sharp through out frame... what???
- During flight with battery at 35%, MA suddenly decides to Return to Home. Controller disconnects then and I have to watch it take off hoping that it finds a clear spot to land. It does not always RTH to the actual Home location taken... Very scary, this has happened twice...
- After a firmware upgrade my MA could not hover still. It would always drift forward right, or backward left. when flying the MA would drift. I spent hours and hours calibrating everying thing on the drone, IMU, vision, sensors, compass, reflashing firmware....
- Always upgrading Firmware on controller, Batterys, Mavic Air, hoping that a firmware will fix the issues.
- Tonight I took a quick flight, video was recorded all choppy. This is it. I give up. Do people really own a MA that is not constant trouble? Because this is the last straw, I give up on this drone.
Jaded Mavic Air Pilot.
