chr.zuercher
Flight distance : 24216 ft
Switzerland
You are completely right, macjunk
And what I suggest is not to level the Bottom. Use the Motormounts instead, because after a hard Landing, the Bottom (Feets) may not be level anymore. Btw: the Feets have Foam on it and they may be deformed after some Landings, so it will be a Cause of unlevel.
You can put a flat Mirrorglass ontop of the Motospindles and use this to level. After Calibration, test if the QC drifts in non-GPS-Mode in a windless Environment. If it does not drift, anything is perfect.
Altitude (controlled by the Barometric Pressure Sensor) remains, but Position (controlled by the Gyro) changes if Level is bad. Compass is a different thing and has to be calibrated more often.
Finally: Calibration is IMPORTANT ! |
