Dji go app no shutter sound when takking a photo
5440 18 2018-5-20
Ranjit
Flight distance : 18530 ft
New Zealand
When I take a photo with the Dji Go App there is no shutter sound. A thin blue line goes around the white button clockwise. Please advise how to fix the issue, I'm in New Zealand.
2018-5-20
Peterx
Flight distance : 1499708 ft
Do you hear any other acoustic message or is the mobile fully silent?
2018-5-20
Geebax
The issue is whether there are any photos saved to the SD card in the aircraft?
2018-5-20
Labroides
Flight distance : 9991457 ft
Check the volume is turned up on your phone or tablet.
2018-5-20
Droner500
I'm pretty sure that there is supposed to be a thin blue line going around the button when you take a photo.
2018-5-21
Ranjit
New Zealand
Droner500 Posted at 2018-5-21 07:08
Yeah you could be right but no shutter sound, with the volume on the phone turned up to its max
2018-5-21
Ranjit
New Zealand
Peterx Posted at 2018-5-20 22:59
Mobile screen is silent with the volume fully turned up
2018-5-21
Ranjit
New Zealand
Geebax Posted at 2018-5-20 23:00
yes photos are saving to the sd card
2018-5-21
Droner500
Maybe you can change it in camera settings on the app. Did you get the drone used, because if you did the guy before you might have set it that way.
2018-5-21
DJI Natalia
Hi, Ranjit. There is no option for shutter sound in DJI Go app. For camera settings adjustment you may refer on this guidelines: https://store.dji.com/guides/dji-go-4-manual/10/
2018-5-22
Eric13
Flight distance : 13982031 ft
Sounds to me like you are filming while pressing the shutter.
You hear the shutter sound only when you are in photo mode.
2018-5-22
Ranjit
New Zealand
Droner500 Posted at 2018-5-21 12:59
It was bought 2nd hand but the shutter sound always worked prior to last weekend....
2018-5-22
Ranjit
New Zealand
DJI Natalia Posted at 2018-5-22 13:26
Cool thanks I'll try that tonight.
2018-5-22
KedDK
Flight distance : 1133038 ft
Denmark
Eric13 Posted at 2018-5-22 13:50
That then must depend on the OS running on the device, on my GL300E with the modified android system i get the shutter click when taking a photo even when filming.
Only if using the pano feature it just give the sound from the first picture taken, rest of the operation is silent what i find unpleasant but not sure if it is just the way it is in general.
2018-5-22
DJI Natalia
Ranjit Posted at 2018-5-22 16:08
You are most welcome, Ranjit.
2018-5-23
DJI Susan
Hello Ranjit, please try to turn up Media Volume to its max, instead of the ringtone to check again. Let us know whether it works.
2018-5-24
itsowen
Flight distance : 359337 ft
If in hdr mode I'm sure I don't hear shutter just see the blue going round in circle
2018-5-25
mccarthr
I have the same problem. I was using a Samsung Galaxy Tab A 10"  with the DJI Go 4 app. I broke the glass on the screen and replaced it. I lost the tablet's speaker function in the process when I replaced the broken screen. The audio jack still plays audio though. This may not be your problem, but it's what I found.
2020-7-15
Peterx
May be the conductors to the speaker or the speaker itself is broken.
2020-7-21
