travisslack
Hey guys, having a bit of an issue getting my x8r and naza to work together.
So I am building a T810, have everything together. if I put the esc directly into the throttle channel of my x8r i can calibrate the motors and they work perfectly. Great, calibrated all my motors one by one no issues!
Next step I connected all my escs to the Naza motor inputs. Then I have my PMU going to X3 and my SBUS to X2 and into the sbus on my X8r (being the only cable going into my x8r). When I turn everything on, i get a single solid beep from all the motors and no fancy DJI noise initiation (like I get on my phantom).
I can connect to the naza assistant, all my controls work, I calibrated the tx through the controller itself as well as the assistant software and everything seems to be fine. I can even go the motor tests and they all spin properly. So as far as I am aware, everything kind of works? I get the yellow light in failsafe and when I switch to GPS mode the led seems to establish GPS connection when I put throttle sticks in the center (blinking green light).
I just can't get my motors to arm! is there a special way of initiation them I dont know of? And why dont i get the dji noise?
Heres a video and some pics of what I am dealing with. I haven't heard or read much about them doing a single beep.
http://i.imgur.com/gYQG7Pn.jpg
http://i.imgur.com/vQMOSTG.jpg
https://vid.me/THkh
any help? thanks
