HedgeTrimmer
Wachtberger Posted at 2018-5-28 12:34
I can fully agree to that. This is also why I tested all three take off modes because my initial suspicion has been that just one or two of them might show the symptoms, while I, normally taking off manually, had not experienced any problems. Now I have had no problems in all three modes and have reported that (like others did as well).
I want to put one thing straight here once and forever: It is not at all my intention to play anything down or to protect DJI. If I find a problem I report it frankly and have done so many times before. When I do such tests it is my goal to help identify the root causes of problems that users are experiencing because the same could happen to me any time too and I would depend on the help of other pilots to get it solved.
Here we have a case where the root cause was perceived to be the firmware update, but some doubts must be allowed too. If there was a general issue, this forum would be flooded by relating reports and complaints. This is clearly not the case. Thus what remains is to try isolating the possible cause to the extent possible and identify which particular user settings or other factors might lead to it. If we are lucky it can be found quickly, but it also can be a long and painful search.
From past experience, I would say you would have to perform same tests you performed on a minimum of 100 Mavic Airs that were selected at random, covering first manufacturing date to April 2018, and selection would need to include multiple countries.
Those tests would also need to be repeated at different times of day, and in different locations. Along with repeating those tests by including variables such as different pilot accounts, drone settings, and smartdevices being used.
It could be there is a common thread, other than firmware .400 update, that is causing various Mavic Air problems being reported here. Below are a few of those various problems that I remember reading about.
Issue being hashed out involving Motor Current Error after May update. Some appear to be real, while others appear to be false warning?
Active Tracking turns into Active Attacking after .400 firmware update.
Couple of cases where after updating to .400, Mavic Airs are being replaced by DJI. Wondering if MAs were bricked by firmware update?
Two cases where updating to .400 resulted in lag problems with Live view that were not present prior to update.
Several cases involving sudden drop in battery power to 0%. Which appear to be false warnings.
Several cases where after updating to .400, Mavic Airs have required re-calibrating or update fails and requires repeating update and re-calibrating.
Even though I don't own a Mavic Air, I have been following Mavic Air problems, guessing there is some commonality between firmware for Mavic Air and Mafic Pro line. And what appears to be a firmware problem with Mavic Pro a couple of people (besides myself) have experienced that cropped up after going .300 on Mavic Pro / RC.
