DJI Diana
Flight distance : 2408 ft
nicksdesign Posted at 2018-5-31 19:12
Thank you for your reply.
The message always indicated that the aircraft serial number failed to upload. However, that may not be a moot point. I decided to try to activate using WIFI connection. It took a bit of work, but I did get it to activate using the phone to connect to the Mavic over WIFI. I then went back to connecting using the controller. I was able to get it to connect. But, it indicates that a software update is needed. This is strange because I have updated both the Mavic and the controller using the DJI Assistant 2 App to the latest versions. I have tried, again twice, to update firmware with the controller and it always fails with a code of 0x640d0103. The Mavic Pro Platinum serial number is: 08QCF3CP021XAY.
Hi Nick, thank you for providing the information, as per check, your drone has been activated successfully. Regarding the indicates that a software update is needed, could you please show us a screenshot? At the same time, please check the firmware version of the drone and the remote controller via DJI assistant2, we'd like to check it for you. |
