WebParrot
Flight distance : 23625 ft
For the time being, keep it simple. Don't mess with the OTG cable. You will be introducing an additional step that complicates getting flying! Most likely your WiFi connection is still pointing to your home based WiFi.
Before you turn on the Remote, before you start up DJI Go 4, and before you start the aircraft, go to the Settings on your phone and choose WiFi.
Start your Remote. Once the blinking light becomes solid, look at the WiFi setting on your phone. The Remote should be listed.
Select it and enter the passcode (if requested). The red light should turn green in a few seconds.
Then start DJI Go4.
Then start the aircraft.
I suspect that your phone has been set to always look for the first WiFi (or "home" connection) as a default. Unless you "point" it to the Remote Controller it doesn't "automatically" switch.
FWIW, if you need to contact DJI Support and have internet connection (your location doesn't matter) you can start a CHat session through this website. At the bottom of this form page there is a link for "support." There you have the choice to start a technical chat. I've used it and it worked, but be patient. It takes a while to work through a problem.
Welcome to the Forum!
