Geebax
'All defects should be replaced, no questions asked in a timely faashion.'
Provided it is within the warranty period.
The noisy fan is a known problem, and only requires a small adjustment to the position of the fan underneath the gimbal cover. You can do it yourself.
If you are in fact formatting the card after every time you copy the material off the SD card, then it should be OK. Are you formatting it in the aircraft using the DJI Go App? It could also be due to the card itself, if it is not fast enough. What card is it?
