Regular Ipad for the Phantom 3 Pro?
7261 25 2015-5-14
CHRISWILLIAMS29
Does anyone use a regular Ipad with their Phantom 3 Pro? If so, how is it working with IOS. If not, is it too big for the controller mount?
2015-5-14
Fulgerite
What is a "regular" iPad?  What specific model are you talking about?  Apple has produced many models of "iPad".  You need to be a bit more specific about which model and generation you are asking about.
I use an iPad Air 2.   It works fine.
2015-5-14
daccattato
Yep, I'm not using my phone or a mini. Just using the iPad Air 2.
2015-5-14
CHRISWILLIAMS29
Im talking about  ipad 2 not air
2015-5-14
ronniearnold
CHRISWILLIAMS29 Posted at 2015-5-15 06:14
Its not supported.  Its way too old.
2015-5-14
CHRISWILLIAMS29
WHAT IS, THE SYSTEM ITS SELF? WHAT DO YOU RECOMMEND? IS IT POSSIBLE THAT I CAN USE THAT IPAD 2 AT ALL, OR DO I NEED A COMPLETE NEW TABLET? I HAVE AN IPHONE 6+ BUT I DONT KNOW IF THAT WILL BE BIG ENOUGH.
2015-5-14
solsystem7
Flight distance : 6550331 ft
CHRISWILLIAMS29 Posted at 2015-5-15 06:44
WHAT IS, THE SYSTEM ITS SELF? WHAT DO YOU RECOMMEND? IS IT POSSIBLE THAT I CAN USE THAT IPAD 2 AT AL ...
The processor inside the ipad2 is too slow. DJI recommends the A7 or newer for their system too work correctly. I have loaded the app onto my old ipad2, but only too get familiar with it, not to use it.
2015-5-14
Jimw_61
I use mine with the iPhone 6 - no issues; also use the iPad Air (2)
Both have advantages and disadvantages
2015-5-14
CHRISWILLIAMS29
Ok thank you for your help, This is my first Phantom so I am rookie! What do you recommend, just using my Iphone or buying a new tablet? if so which is best for DJI?
2015-5-14
nickmedici
Flight distance : 88287 ft
CHRISWILLIAMS29 Posted at 2015-5-15 07:13
Ok thank you for your help, This is my first Phantom so I am rookie! What do you recommend, just usi ...
You certainly do not have to buy a new device as long as you have one that is compatible with the app. They all work just as well as others. It really just depends on what size you want your screen to be. I use an iPhone 6 plus and it's good enough.
2015-5-14
CHRISWILLIAMS29
do you have your P3P already? If so I read that iOS is not working correctly . Users are already asking for an update.
2015-5-14
nickmedici
CHRISWILLIAMS29 Posted at 2015-5-15 07:47
do you have your P3P already? If so I read that iOS is not working correctly . Users are already ask ...
Yes I do. I have had it since the app has come out and I have not had that many problems. It is good enough to use without devastation like errors.
2015-5-14
drcampbel
I use an original IPad air, works very well.
2015-5-14
aburkefl
Flight distance : 78612 ft
ronniearnold@ya Posted at 2015-5-15 06:37
And the iPAD 2 won't fit in the controller either.
2015-5-15
CHRISWILLIAMS29
good to know. ill see how the iphone 6+ does , but it seems everyone uses the ipad air
2015-5-15
artichoke
How about an Ipad 4?
2016-1-16
SFGiants24
Flight distance : 394524 ft
This has been covered many, many, many, many............times. please do a search.
2016-1-16
artichoke
SFGiants24 Posted at 2016-1-16 17:39
It probably would have been easier for  you to type "yes" or "no", but whatever.  Anyway I am using the Ipad 4 and it seems to work fine.  Ordered a third party add-on to the top of the holder that's supposed to hold it successfully.
2016-1-20
TexasSpartan
artichoke Posted at 2016-1-20 19:52
It probably would have been easier for  you to type "yes" or "no", but whatever.  Anyway I am usin ...
Yeah it cracks me up when people write a paragraph telling you to search a topic when it's so much easier to just answer the question. that said, I just ordered the ipad mini 4 to use. My 6+ is too small for my liking.
2016-1-20
RedHotPoker
Flight distance : 165105 ft
I had at first, bought and tried an iPad Mini. It was a great fit, nice screen size too, but overheated after only one intelligent flight battery worth of flight.
So I traded it up, to an iPad Air 2 64gb Cellular. Wow, I can fly four full flight batteries, and it remains cool to the touch. & never a problem, concern or negative hiccup.
What a work horse, it's a like a Clydesdale...
Air 2 Cellular. It just works.
RedHotPoker
2016-1-20
artichoke
TexasSpartan Posted at 2016-1-20 21:37
Yeah it cracks me up when people write a paragraph telling you to search a topic when it's so much ...
Just to be clear, I am not using the Ipad Mini 4 but a regular 11 inch Ipad 4.  We got it about 3 years ago and it's still working -- much longer than I thought it would last.
2016-1-21
gherd
I started with an iPhone 5 even though it was not listed as supported.  The video was a little choppy but otherwise it worked fine.  I switched to an iphone5s and the video streaming was much better.  No real difference in performance of DJI GO.  I just setup an ipad mini which is not supported due to the processor speed.  Like the iPhone 5, it has a hard time rendering video with no glitches.  Control seems fine but slightly slower.  I have seen a controller with an ipad 4.  It had a mount specifically made for the ipad, so supporting it was not an issue.
The mini seems the perfect size.  Lighter on the controller and a decent size display.  Once I recover from buying the Phantom, extra battery and other basics, I will most likely get an ipad mini 4.
2016-1-21
fansc138c4ba
Flight distance : 2159 ft
Will  an iPad mini 2 or 3 work  with a dji phantom 3 pro?
2020-6-13
Geebax
fansc138c4ba Posted at 6-13 13:46
No, at the very least you need an iPad 4.
2020-6-13
endotherm
Flight distance : 503241 ft
Geebax Posted at 6-13 14:28
I've always used an iPad Mini 3 (FGNV2X/A) with my P3A.  It has worked flawlessly and still seems to have adequate power, even with the current demands of the app.
2020-6-14
Geebax
endotherm Posted at 6-14 02:06
OK. I went straight for the Air 2.
2020-6-14
