EdisonW1979
Flight distance : 1535679 ft
Thanks for the tip! This is actually what I did yesterday when I flew with my iPP 10.5 w/MavMount, but the only thing I did differently is before starting the flight, I hooked up to my iPX via Personal Hotspot, then went into GO 4 and Map view, downloaded the data, then went to Control Centre and killed Wi-Fi, and voila, had my maps!
They held for all my flights, but since I didn't exit GO 4 at anytime after caching the data, don't know if it got wiped out or stuck around between sessions. Will have to see if that works now.
On a side note, I see that GO 4 v4.2.20 is a BATTERY HOG!! I flew thru 2 batteries on my iPP 10.5, starting with 94% battery, and after the flights it was down to 50%!!! And this iPP is only a month old, and I do usually get days of battery life out of a single charge, so GO 4 is BAD in battery on iPP!
Cheers
