Spirytus
Flight distance : 126864 ft
Jet760 Posted at 2018-6-24 05:31
If this doesn't work I could crash the drone as when the errors happened the drone showed a extreme flying on its own. please advise warranty will still replace if this occurs . Or I can send DJI the flight log to show how the aircraft moved away on its own with no input from the pilot
In my experience DJI support has been quite good in honoring their warranty but what you're looking for is written guarantee on a public forum -- I don't think you'll get that here.
My suggestion:
Since your Phantom is still brand new (I.E. within the exchange period), and assuming you purchased it from the DJI store:
- Raise a ticket with DJI support for the VPS issue you described ASAP.
- After a short wait they'll advise you to perform the calibration that Wanada posted, also possibly the controller and compass.
- If you feel uncomfortable flying regardless, you can discuss your concern with the service rep. Likely he/she will send you a shipping label to send your drone off to a repair station; You will be able to get an exchange or a refund.
Depending where you live, in can take some time (for me in Canada takes roughly 3 ~ 4 weeks) before the replacement arrives.
If you purchased it through another retailer, talk to them about an exchange.
Stating that, I would definitely try the VPS calibration first. Once successfully calibrated I would:
- Test the controller in the simulator that comes with assistant 2 (make sure your propelers are off). Once done:
- Go to an an empty football field somewhere.
- Power on the drone and turn off VPS through the GO4 app and wait for near full satelite bars.
- Check the heading of the drone, make sure it is correct by looking (expanding) the map.
- Make sure the GO4 app is in beginner mode and/or make sure the controller toggle is set to P Mode then take off to an altitude of 15m (or higher).
- Test GPS lock is working (P mode) let it hover for a bit to make sure.
- Then finally switch on VPS and test it carefully by descending below 10m and hovering infront of you etc...
Your flight experience seems to differ however, so if in doubt, just send it back and let them deal with it while you get a new one.
P.S. I have to ask; The VPS cameras come with protective stickers, you removed them yes? The cameras are not abstructed / covered by something right?
