Nigel_
Flight distance : 388642 ft
Bashy Posted at 2018-6-24 19:22
If you are a little worried, just make a point of renewing the original ones on a yearly basis, they should last at least that long
The plastic ones will last a lot longer than that, unless the props collide with something very hard, like solid rock, and then they may save the motors from damage by taking the damage themselves.
If you ever shatter the props, or cause other serious damage then replace the plastic mounts with new plastic mounts, otherwise they may fail while in the air. It is very unusual though. |
