HedgeTrimmer
Aardvark Posted at 2018-6-25 18:21
Only one is active, it wouldn't be comparing the two. If the active compass shows an unacceptable error level, the redundant compass will become active. So they never disagree. Lets suppose that one compass were to fail completely, then the other takes over. That is the whole point of redundancy, Likewise the dual IMU, if one fails in operation the other will take over.
I know only one is active at a time. You are missing the point.
When one compass (magnetic field strength sensors for XYZ axis) is showing a real difference in magnetic fields, then one of compasses is either out of calibration or drone is being affected by a source of magnetic interference very near the drone.
Either way, take off is a risk. In case of source that close to drone, the drone needs to be moved. In case of calibration, If something goes wrong with drone selected compass, the drone is left switching to out of calibration compass. |
