WebParrot
Flight distance : 23625 ft
Go over to MavicPilots.com to this thread by Forum Staff Member, dirkclod ( he knows his stuff )... the settings are in the Go4 editor "Settings" under the "Me" https://forum.dji.com/forum.php?mod=viewthread&tid=118959 . When you get to this thread, scroll down to Post #7 and you'll see three images. Following them will guide you to the watermark settings (and allow you to set your own, if you desire.
AND... if you're not a member of that forum.... JOIN... there are dozens of really helpful pilots who hang out there. Way more helpful that some of the forum admins here :-)
[EDIT... oh what the heck... I'll list the steps here, too :-) ]
Open Go 4
Touch the "Me" icon at the bottom-right of the screen
Now touch the 'gear' icon (for settings) at the top-right of the screen
Then choose the "Privacy Settings"
You will see a list with toggles. It's likely that yours will all be "on" ... I just tapped them all, turning them off. There's also some other notification and project participation choices you can consider.
If you use multiple devices as flight monitors you'll need to re-set each device's Go4... otherwise it will come back on when you change!
Hope that helps.
