3-D
Flight distance : 635764 ft
Yes, as jerry said, you'll need to keep in mind that wind speed is generally higher as your altitude increases. If it is possible, I would try to fly out into the wind, so that your flight back is with the wind. That will help you a lot on your return trip.
Also, Yes. the same materials you use to clean your computer are fine for cleaning your Mavic. I actually use clorox wipes to clean all of the surfaces, except for the camera lens. I use lens cleaner and a soft cloth for the lens. and i use compressed air to blow out the vents.
Welcome to forum. |
